A couple of little programs if find useful.
We ask that we keep it polite and constructive. Thankyou.
Wilson
Registered for: 4 years 6 months
Has thanked: 5 times
#290
Post by Wilson »
Here are a couple little programs I recommend...
I use an online password vault also the browser but just in case they are lost of just don't work any more I have a little portable program called KeyPass. It is a simple little program that can create passwords and stores them encrypted into a local storage file. It has heaps of plugins etc but I've never used any of them.
https://keepass.info/
Another little program is a windows widget. It gets its data from Weatherzone. Its actually no longer officially supported by Weatherzone but hey have kept the database it uses to update the weather all the time working and current. Everything works on it except for the radar. Also it is important not to see if there is any updates because there isn't one and it will break the program. The new one was the same anyway but with ads included. I've added it as an attachment.
weather-tracker-setup-2.rar
(2.95 MiB) Downloaded 405 times
word count: 163
Re: A couple of little programs if find useful.
#303
One I find useful is one I use to do a mirror image of my C drive, operating system and files on my windows PC.
It is called Macrium Reflect. It is the free version. https://www.macrium.com/reflectfree
I have it do a auto backup once a month. The auto backups can be found in Backup Templates.
word count: 59
Return to “Other Interests/Topics”
