The gist of the outgoing email was as follows:
NBN FttN - announcement by the Minister
Basically to be treated as an " Expression of interest for faster / fibre connectivity ".
References:
https://minister.infrastructure.gov.au/ ... 25000-jobs
and
https://www.paulfletcher.com.au/media-r ... oadband-to
Code: Select all
Good evening Belinda & Dylan
We're connected to the Caboolture POI 4CAB since Feb 2016 on the NBN MTM FttN technology.
We're currently with Superloop, same address, on the 100/40 plan since February 2020 and would like to be considered for this " upgrade " to a higher plan of at least 250Mbs/100Mbps, as we run a hub and spoke VPN connected via the hub of Zurich to several sites worldwide including Doha, Singapore, Chennai & Tokyo.
Most of these spokes and the hub were long on Gigabit plans and this upgrade appears to be fitting for our planned needs. I'm willing to consider a 24 month option if the pricing and associated terms remain attractive enough.
Can you, therefore, register on our behalf this interest to the wholesaler NBN and update us on this matter in a timely fashion from time to time ?
Thank you and best regards
Zurich
for xxxxxx & yyyyyyyyyyyyyy
Caboolture
07 416 xx xxx
