How to Enable Google’s TCP BBR on a Linux VPS ( KVM )
Any discussion related to VPS Servers.
Registered for: 4 years 1 month
#151
What da fark is this BBR thingy ??
https://en.wikipedia.org/wiki/TCP_conge ... ol#TCP_BBR
More:
From Google about the BBR
BBR ("Bottleneck Bandwidth and Round-trip propagation time") is a new congestion control algorithm developed at Google. Congestion control algorithms — running inside every computer, phone or tablet connected to a network — that decide how fast to send data.
Google’s TCP BBR, or “Bottleneck Bandwidth and Round-trip propagation time,” is a congestion control system based on cutting-edge technology. It is the same system used for traffic through Google.com, as well as YouTube. It was the reason that YouTube’s network throughput was increased by 4% annually. Moreover, Google’s BBR also significantly reduces latency as the querying, and queuing delays are minimised.
This guide is for you so that you can enable Google’s BBR on your Linux virtual private server aka VPS.
There would be two steps in the guide, where step 1 can be optional in some instances. Let us start!
Step 1. Check and upgrade your existing Linux kernel
We need Linux kernel version 4.9.0 or higher to support Google’s BBR. We will guide you on how to update it for both CentOS 7 and Ubuntu.
To check your current kernel version, run this command on terminal:
Code: Select all
uname -r
If this command returns a kernel version higher than 4.9.0, then you can skip step 1.
For CentOS 7 Based Systems:
https://en.wikipedia.org/wiki/CentOS
1) Install Elrepo repo
To update the CentOS kernel, we need to install the Elrepo repo via the following commands:
Code: Select all
sudo rpm –import https://www.elrepo.org/RPM-GPG-KEY-elrepo.org
and
Code: Select all
sudo rpm -Uvh http://www.elrepo.org/elrepo-release-7.0-2.el7.elrepo.noarch.rpm
2) Update your kernel
To install the updated kernel, run the following two commands:
Code: Select all
sudo yum –enablerepo=elrepo-kernel install kernel-ml -y
and
Code: Select all
yum list installed kernel
3) Set default boot entry
Run this command to see the list of kernels:
Code: Select all
sudo egrep ^menuentry /etc/grub2.cfg | cut -f 2 -d \’
You should find your newly installed kernel at the top of the list. Then run the following command:
Code: Select all
sudo grub2-set-default 0
4) Reboot and verify
Now reboot your VPS, and after it turns back on, rerun the following command to verify the install:
Code: Select all
uname -r
Ubuntu 18.04 Based Systems
https://en.wikipedia.org/wiki/Ubuntu
The kernel version should be compatible with Google’s BBR if you are running Ubuntu 18.04. However, you can still upgrade the kernel using the following commands.
Code: Select all
cd /tmp/
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-headers-5.4.13-050413_5.4.13-050413.202001171431_all.deb
or newer kernel - your choice!
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-headers-5.4.13-050413-[color=#408000]generic[/color]_5.4.13-050413.202001171431_amd64.deb
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-headers-5.4.13-050413-[color=#80BFBF]lowlatency[/color]_5.4.13-050413.202001171431_amd64.deb
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-image-unsigned-5.4.13-050413-generic_5.4.13-050413.202001171431_amd64.deb
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-image-unsigned-5.4.13-050413-lowlatency_5.4.13-050413.202001171431_amd64.deb
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-modules-5.4.13-050413-generic_5.4.13-050413.202001171431_amd64.deb
Code: Select all
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.4.13/linux-modules-5.4.13-050413-lowlatency_5.4.13-050413.202001171431_amd64.deb
and run them all !
Code: Select all
sudo dpkg -i *.deb
After running the commands, reboot your VPS by running the “reboot” command.
Step 2. Enabling Google’s TCP BBR
The instructions below are the same for both CentOS and Ubuntu.
To start, open “/etc/sysctl.conf” in any text editor, or run the command to open it in vim or nano ( your preferred text editor ) - the lazier me would edit it from Webmin's File Manager
Code: Select all
sudo vim /etc/sysctl.conf
At the end of the config file, add the following lines:
Code: Select all
net.core.default_qdisc=fq
and
Code: Select all
net.ipv4.tcp_congestion_control=bbr
Then save the file, and refresh your configuration using this command:
Code: Select all
sudo sysctl -p
Google’s BBR congestion control system has now been enabled on your VPS, to verify this, run this command:
Code: Select all
sysctl net.ipv4.tcp_congestion_control
If the enabling process were successful, the output would be:
Code: Select all
net.ipv4.tcp_congestion_control = bbr
You have now successfully enabled Google’s TCP BBR on your VPS!
word count: 841
Return to “VPS Servers”
