Cost – On a budget, or looking to get the most for your buck. It might save you bit$ on electricity, time to setup a machine etc.
Backup – As with anything IT, you definitely want backups, especially in the day and age where ransomware is off the charts, and folks are working remotely due to the effects of COVID-19. A cheap VPS with a sufficient amount of storage is a good use case as a backup server. Or for those who want to implement DRaaS ( disaster recovery as a service ) or similar environments.
VPN – A lot of users use a cheap VPS particularly to set up their own VPN. Some use cases include bypassing the GFW in China as it is a communist country, this allows consumers to browse the internet without censorship or simply to access otherwise geo-protected content ( get a VPS in the USA for eg Netflix, Prime USA etc. )
Dev Environment – If you are a developer, you'd know that developing takes time, and with that you’re most likely looking for a cheap VPS for the duration of your development, testing and so on. An el cheapo VPS can be a great choice.
Most VPS’s include a control panel ( such as SolusVM or Virtualizor ) where you can instantly reinstall your VPS server to a different operating system, making this perfect as a dev environment as you can always test different operating systems and always start over if needed.
Websites That Need Extra Horsepower – if your website is outgrowing shared hosting, which itself is generally cheap, you might be looking for additional resources while still looking at cost, comparable to shared hosting cost.
A cheap VPS would be ideal for this. A VPS provides you with more resources and more control compared to shared hosting, and this translates to better performance for your website. If your website visitor count is growing it might be time to consider upgrading to a VPS.
Game server Hosting – If you are looking to set up a game server for the first time, a cheap VPS is a way to go! Considering setting up a game server such as a Minecraft game server, Garry’s Mod game server http://www.gametracker.com/search/garrysmod, Rust game server ( https://rust.fandom.com/wiki/List_of_Server_Providers ) etc. ?
A VPS provides you with complete root access in order to set up and install your game server the way you desire. Compared to slot game server hosting, with a VPS – you are in total control of the server’s environment and are able to customize it in any way you desire, or even set up multiple game servers on the same VPS as long as your server has enough resources to support it.
Top Reasons to Choose a Cheap VPS
- JuniorGeek
- Registered for: 5 years
- 5
- Location: Caboolture 4CAB POI FttN / Zürich GigETH DOCSIS 3.1
- x 2
- x 6
- Mood:
- Has thanked: 26 times
- Been thanked: 32 times
- Gender:
- Zodiac:
- Contact:
