Even if an attacker was to guess your SSH passphrase, without the SSH private key file, this knowledge is not sufficient to allow him to login.
This tutorial will walk you through creating an SSH key on Linux, macOS, or Windows. In following tutorials we’ll show you how to use it to login, and optionally disable password-only logins.
Public/Private Key Basics
SSH keys use public key cryptography. When you generate a new SSH key, you will have two files: a private key and a public key.
The private key you should keep on a trusted system at home, such as your personal PC, and it should never be shared with anyone. The public key will be placed on every server you wish to log into. The public key is truly public – you could post it on eg Ausgeek, Reddit etc. and your security would in no way be compromised.
Virtually all Unix-based systems use OpenSSH from the OpenBSD project. OpenSSH supports several different encryption algorithms and you will need to choose which algorithm your key will use. Which algorithm you choose to use will be based on what kind of server you are connecting to.
Note that this is server-dependent, not client-dependent:
- If your server has OpenSSH 6.5 or later, such as Debian 8+ or CentOS 7+, you should use ed25519 i.e.
- If your server is older, you should use RSA. Specifically, RSA with a 3072-bit key (which is the default).
- If you will be connecting to many servers and some are old, then RSA is the logical choice so you can use the same key across all servers.
- long (16-32 characters or more)
- a mix of uppercase/lowercase letters, numbers, and symbols
- no Dictionary words
- don’t reuse passwords
Generating a New SSH Key
Linux/macOS
OpenSSH includes a utility called ssh-keygen that we’ll use to generate a new key.
First, make sure you have an .ssh directory in your home directory. You can actually keep your ssh keys anywhere, but this is the traditional location. This directory should be mode 700 (drwx——). To ensure your directory is setup properly, open a terminal copy/paste the following:
Code: Select all
[ ! -d ~/.ssh ] && mkdir ~/.ssh ; chmod 700 ~/.Code: Select all
ssh-keygen -f ~/.ssh/my-ssh-key -t ed25519 -C 's-f: This is the file in which your key will be stored. After generation, two files will be created: my-ssh-key (the private key) and my-ssh-key.pub (the public key). Of course, you can name this file anything you wish.
-t: In this case, we’re using ed25519. You can also enter ‘rsa’ here to create a RSA key.
-C: This is a comment that will be included in your SSH key. This makes it easier to keep track of multiple keys.
There are other ssh-keygen parameters – see the man page if you’re curious.
Once you give the ssh-keygen command, you’ll be asked to enter a passphrase.
Here is an example of generating a key:
Code: Select all
$ ssh-keygen -f ~/.ssh/my-ssh-key -t ed25519 -C 'ssh key for kgb@geeee.ru'
Generating public/private ed25519 key pair.
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in /home/example/.ssh/my-ssh-key.
Your public key has been saved in /home/example/.ssh/my-ssh-key.pub.
The key fingerprint is:
SHA256:gIY5DGVDwq2ncvsz6KN1xthvO9LrPdySEl++87ZxRK8 ssh key for kgb@geeee.ru
The key's randomart image is:
+--[ED25519 256]--+
|+o* |
| * o . . |
| o S . .|
|..oo=. + = . E |
| .+o+.=.* + .o |
|.o.o.*==.o.=o. |
+----[SHA256]-----+Code: Select all
$ ls -l ~/.ssh
total 16
-rw------- 1 example ausgeek 2655 Sep 11 15:35 my-ssh-key
-rw-r--r-- 1 example ausgeek 580 Sep 11 15:35 my-ssh-key.pub
$ cat ~/.ssh/my-ssh-key.pub
ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIGPw+oAB0cfuJWindows
On Windows, we will use the venerable PuTTY package. It’s available for free download as either a .msi ( Windows installer ) or as a set of binaries ( https://www.chiark.greenend.org.uk/~sgt ... atest.html )
To generate the key, we will use puttygen.exe.
Once you’ve either installed via the installer or downloaded puttygen.exe, fire up that application:
If you are generating an RSA key, make sure to change the “Number of bits in a generated key” to 3072.
If you are generating an ed25519 key, then there is nothing to change.
Click “Generate”. You’ll be prompted to move your mouse over the app’s window in order to generate entropy.
Next, modify the key’s comment if you wish and enter your passphrase.
Then click “Save public key” and “Save private key”. You can save these wherever you wish but be sure the folder is kept safe. PuTTY will save your private key with a .ppk (PuTTY Private Key) extension, and your public key without an extension. In this case, they’ve saved them as “my-ssh-key”:
Before you close puttygen.exe, you’ll also need to save the public key in a format you can install on the server. At the top under “Key” you will see a section marked “Public key for pasting into OpenSSH authorized_keys file”.
Highlight the text in this box with your mouse, hit Control-C, then open Notepad.exe and paste it into a file.
Save it alongside your keys in a file called “my-ssh-key pastable.txt”:
That’s It!
You’ve successfully generated an SSH key.
A brief video About Key Exchanging:
